Someone I work with offloaded an older Toshiba laptop to me. Seems to have a 1.5GHz Celeron, 512MB ram, and Intel 915GM. Model is M55-S135
They gave it to me thinking that the HDD was bad. They told me to keep it, but if it was that simple I would have returned it.
The HDD is bad, however, swapping in a good hard drive gives the same issues.
Issues are:
POST is fine.
When trying to load an OS, be it XP or Ubuntu, I get "CRC Error --System Halted"
I cannot run Ubuntu Live at all, and only 2 times I have been able to get through part of XP install where it's copying over the files. Then it just dies saying the files cannot be located.
I have reflashed to the latest BIOS from Toshiba's website. However, the flash seems to die at the end, resulting in a total shutdown of the machine. I do not see any "Completed" messages.
Ideas? Things to try?
Issues are:
POST is fine.
