Need Help with Koolance Exos-2
Pegesus
Ok...
This is my first Liquid Cooling system. I am trying to connect it but am coming to a road block. Where do the tubes from the System go once you slip them throught the Slot Adapter in the back of your computer. From the directions in the manual it looks as tho the are routed through a Koolance CPU or GPU but i have no idea what that is or where to find it. It was not included in the packaging of the System.
Please help this is driving me nuts.
Thanks
Generally when you buy any Koolance gear you don't get a waterblock unless the vendor bundles one in on some type of special offer.
You'll need to buy a CPU and/or GPU block.
yeah i have the manual but it was vague about what was needed. I guess i will have to buy the CPU and GPU block only problem was i needed it today. Oh well i'll try to find one as fast as possible. Thanks for the help.
straight from koolances web site
"What do I need to buy?"
Whether you purchase a Koolance PC2-650, PC2-901, Exos, or RM1-4U, the primary cooling components will already be installed in your system. This assembled "backbone" includes: the radiator, reservoir, pumps, control board, top fans, and front LED temperature display. Liquid coolant and extra tubing are also included with the system.
In addition to the basic system, however, you will need to choose which liquid coolers you would like to add. For example, Koolance offers liquid coolers for the CPU (including dual), video card chipset, motherboard Northbridge chipset, and hard drives. It is your decision which devices you would like to liquid cool. If you wish to add more components later, tubing is included with each system and from the Koolance website.
There are two essential components you will need to operate your Koolance System: a CPU Cooler and a power supply. A CPU Cooler is not included with the system because Koolance often has different models available simultaneously. You're free to choose which CPU Cooler best suits your needs. (Note: For your convenience, some Koolance resellers may sell system "combos" with the latest CPU Cooler. Please check with your dealer.)
