need help with installing motherboard
si0dine
im building a computer for the first time, and i just got all the parts..
chaintech nforce 4 ultra
chaintech 6600gt
amd athlon 64 3500+
seagate hd sata2
i need help with a few things
first do i need a 20 to 24 pin atx power supply converter? the psu i have has 20 pins the motherboard has a 24pin slot, but on their website http://www.chaintechusa.com/tw/eng/product_spec.asp?MPSNo=13&PISNo=318 it says it 20 pin ATX Power connector
second where does the cpu fan plugin go? it says connect the northbridge cooling fan to FAN4 in the manual
heres a picture of the fan slots http://www.hobonation.com/~dump/userfiles/siodine/help.JPG
third for connecting the power switch, reset switch, and leds
how do i know which wire is positive.. the wires it has are blue and white, red and white, and black and white... also theres an A on the connector where the non-white wire is
You'll probably be fine without the adapter. I've seen many others in various forums using 20 pin PSU's on various NF4 boards without problem, as long as they are not trying to run 2 6800GT's or Ultras in SLI.
You can either plug the CPU fan into the CPU fan header of the mainboard or use an adapter if necessary to change the fan connector from 3 to 4-pin molex and attach it to one of the 4 pin connectors coming from your PSU.
As for the connections, the color that all the connectors have in common (white in your case) is negative.
thanks i really appreciate your help, but im still a little confused to where i should connect the cpu heatsink/fan.. whats the northbridge cooling fan?
=X Heatsink fan should be placed on top of the CPU and the fan cable should be placed in a fan power connection usually says CPUfan1 (CPUFAN) or something near it. Look at your motherboard layout guide.
Looks like your motherboard has passive cooling which means if you want to add a active cooling fan to your nforce4 chipset you will plug in the fan to Fan4. And the CPU Fan goes to CPUFan. ;)
Northbridge Cooling Fan means the Fan cooling your nforce4 chipset...
ok so the northbridge fan would be like the fan on the plastic window thats directly blowing on the motherboard?
No Ignore the Northbridge fan comment you dont have one. Your motherboard gives you th option of adding one, If you would like to add one I guess it leaves you a power slot fo that.. And usually blowhole fans use molex connection.. ;)
