SSTwinrova
- Apr 14, 2004
Last year (summer-ish) I built a HTPC to connect to our HDTV. I thought I had planned enough about making sure to keep it cool enough (no big heat producing components in the system), but apparently I was mistaken. Here are some pics of the current setup:
http://www.FreeImageHut.com/view.php?file=3377-qkb88i3g.jpg
http://www.FreeImageHut.com/view.php?file=3378-48nuchu7.jpg
As you can see, the computer is inside a glass door beneath the TV, but I removed the dividing shelf that allows for two components to be stored there. The problem is, with the glass door closed, the temperature gets up past 60 in there when the computer is on for any significant length of time. The solution thus far has been to have the glass door open whenever the computer is on (keeping the temps down in the 40 range) since removing the door entirely isn't an option (Parent-AF and all...).
Inside the space are two holes in the back that are designed for feeding cables:
http://www.FreeImageHut.com/view.php?file=3379-54v8worq.jpg
http://www.FreeImageHut.com/view.php?file=3380-tuf4bl6z.jpg
My thought is that these have to be somehow utilized to increase the airflow and keep the temps down with the door closed. Cutting additional holes is also not an option (PAF again), but slightly expanding the size of one of the holes is possible. The best idea I've been able to come up with would be to maybe get like a USB powered "case fan" and mount it up against one of the holes, feeding all of the cables through the other. All of the fans I've been able to find like this have LEDs and such.
So, does anyone have a suggestion or idea on what I can do?
