Need help with gaming SFF
Hayblum
Well basically I have a budget of about $1600, and I'm trying to figure out a good high end gaming sff build. I have never built an sff before and I don't really know much about what will fit into one. I was thinking about going with a quad core cpu (q6600 probably) but I also want to fit a 8800gtx in there (and i dont know which kind of case can support that).
So if anyones got a good build for me (including all parts for under 1600) please post :) thanks!
Well, the SG03 is probably your best bet if you want a 8800GTX vid card. Its a tower-like SFF case. Think mini-tower and thats pretty close to it. For a Q6600 you'll also want a NT06-Lite hsf to go with it. Mobo choice comes down to wether you plan to overclock or not. If you want to overclock the DS2R and the P5K-VM are you only two real good choices. Most people that are OCing their Q6600s are using the DS2R as the preferred mobo. RAM choices are plentiful. I think most are going with the 667 variety. Crucial Balistix are very popular and not overly expensive. You'll want a nice psu to go with it. I would say the Corsair HX620w would fit the bill nicely. It fits inside the SG03 and will run a 8800GTX quite nicely. It'll also allow you to OC if you so desire. The Corsair HX520w will do the job as well but if you plan to OC the HX620w gives you more legroom for that and future upgrades. The HX620w is also modular so you only use the cords you need and this makes it easier on wiring maitenance.
The rest you'll need to decide what you want. For a hardrive anything from a regular SATA drive to a RAPTOR will work fine. There are some cheap SATA optical drives too you can choose from for your CD/DVD needs.
Depending on how much money you want to save, overclocking, and whatnot...
Silverstone SG03
Sugo Pack (if needed for portability)
Q6600
P5K-VM (for overclocking, long IDE cables)
GA-G33M-DS2R (for not overclocking.)
8800GTX
2GB of something.
Sound card?
Wireless card?
DVD burner of sorts.
320GB Seagate
Silverstone ST50EF or ST60F (modular) with short cables.
NT06 for additional CPU cooling. Not sure how well the stock cooler fares in the SG03.
Fans.
Comes out at $1500 for everything without a question mark, P5K-VM, and the ST60F. Roughly. Throw in $80 for the sound card, $20 for wireless.
Thanks for all the suggestions so far guys. I was wondering though, are there any smaller cases that can still fit the 8800gtx? I plan on traveling with this computer a lot and airline attendants tend to give me shit even with a mid tower.
the gigabyte board is better for you.
the sugo 3 is a great case with 2 120mm fans in the front if you want, and it will still have enough room for your gtx.:D
The gigabyte board is awesome but it should be noted that you need good ram with it. With a 266FSB CPU it will not run a 1:1 ratio. The lowest it will go is 1:1.25 so to do 400FSB you need ram thatll hit at least DDR2-1000.
Just a heads up since alot of threads dont mention it, I found out after I bought it.
Or you can just get a 333FSB CPU (E6x50) which will let you use the 1:1 divider. If you read the thread GA-G33M-DS2R, it should give more info about it, a lot of that thread is about the dividers and overclocking capabilities.
Ok so this is what im thinking for the final build. Please tell me if you have any suggestions for this build.
Case:SILVERSTONE SG03-B Black Aluminum MicroATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811163085
Hard Drive: Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
http://www.newegg.com/Product/Product.asp?item=N82E16822136012
Video Card: EVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.asp?item=N82E16814130072
Power Supply: SILVERSTONE SST-ST60F ATX 600W Power Supply 90 - 264 V
http://www.newegg.com/Product/Product.asp?item=N82E16817163109
System Memory: Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.asp?item=N82E16820146565
Motherboard: GIGABYTE GA-G33M-DS2R LGA 775 Intel G33 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813128053
CPU Cooler: SILVERSTONE NT06-LITE CPU Cooler
http://www.newegg.com/Product/Product.asp?item=N82E16835220019
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Processor
http://www.newegg.com/product/Product.asp?item=N82E16819115017
Sound card and DVD drives are already taken care of.
Thanks for all the help guys!
