Need help with FreeNAS
KapsZ28
For now I just downloaded a VM of FreeNAS. I am using the WebGUI since I have never used this before and don't know any command lines. I must be missing something, because I don't see an option to setup permission on a share. I am using
CIFS/SMB, so I can setup a share to work in Windows. I set up the service as follows.
Authentication: Local User
NetBIOS Name: freenas
Workgroup: WORKGROUP
I created a share called "Testing" which is browseable. If I go to Start>Run and type in \\freenas, I am able to see the new folder called "Testing." If I try to access "Testing" I am prompted for a UN and PW. I use the UN and PW of a user I created with admin rights and nothing happens. It just keeps prompting me for a UN and PW.
The file share shows up in My Network Places too. I just can't figure out how to setup permissions on it.
