styckx
- Aug 16, 2003
Take in that I will be adding the fan at the top..
Also, the front fan doesn't get much airflow due to the grill holes blocking some airflow, it does get airflow just not the max it could if it wasn't obstructed..
I need some suggestions on what the best configuration I should use for this setup for max cooling/airflow in this box...
Also, take in the fact each side panel has vents at the bottom of each..
Thanks in advance..
