- Nov 22, 2004
I am sort of new to overclocking however I read all of the how-to's so I am now somewhat familiar with how to go about overclocking.
I have my E6600 on a Asus P5B Deluxe board. Earlier today I pushed it too high and it was hitting 60C so I pushed the values back down. Here is what I currently have set in the BIOS:
CPU Frequency- 275
DRam Freq- DDR2-750MHZ
PCI-E- 100
PCI- 33.33
Spread Spectrum- Disabled
Memory Voltage- 1.90V
VCORE Voltage- 1.3375V
Advanced Menu:
Mofify Ratio Support- 9
C1E Support- Disabled
Max CPUID Limit- Disabled
Vanderpool Technology- Disabled
CPU TM- Enabled
Execute Disable Bit- Enabled
PECI- Disabled
Now, CPU-Z is saying that I am now running at 3375.2mhz (375X9). I am getting a reported idle voltage of 1.296V and a load voltage of 1.272V.
With those settings I ran Orthos for an hour (yes I know I should do 12-24) and it ran without any problems, so far. As far as temps go I am now running at 35C idle and ~53C load.
I need some opinions. Is my vcore too low? I am reading some of you set your vcore to 1.5V, which quite frankly I dont know how the hell you cool that thing. I use a DangerDen TDX block and mine and with the above settings I am nearly hitting that 60C critical point.
Should I change any of my values or does everything look good to go for a 24 hour test?
Any input is appreciated!
UPDATE: Measured my VCore with a DMM and read 1.321. Looks like the software really sucks for reading voltages!
CPU Frequency- 275
PCI-E- 100
PCI- 33.33
Advanced Menu:
CPU TM- Enabled
PECI- Disabled
