Hello, I'm new to overlocking. I've read the guidlines associated with OC'ing a dual core CPU and I understand that the Vcore will have to be raised if one plans to use a much higher FSB speed; that the NB voltage might have to be increased; that the RAM timings should be "loose" at first...voltage might be adjusted as well; and something about adjusting the FSB VTT a tad if need be. ...Something along those lines anyway. But how does one know which one needs to be adjusted when and by how much?
I have a E6420 with a 'stock' voltage (according to the BIOS on my MSI P6N SLI Platinum mobo) of 1.28v; 2 GB of DDR2 800 (4-4-4-12; 2.2v - rated) Patriot Memory RAM. I'm also using the stock HSF. Now, without even adjusting the Vcore, I can get the FSB to 375 with the CPU at 3 GHz. I didn't do any of the prime95-like tests but it seemed stable enough to play my games and surf the web. However, when I try to get to 3.2 GHz with a 1:1 ratio...the computer won't even POST and it gives me a blank screen. I've tried increasing the Vcore a little and then to 1.35v (tis what was rated as the max on the box)...no go. So I figure it's either the RAM timings, NB voltage, or the FSB VTT...or a combination of both that I need to adjust. Im just at a loss for which one to tweak (first).
Ive tried reading the manual that came with the board but it wasnt so useful. >FSB VTT Voltage : This item allows you to set the FSB VTT voltage. Well geez, thanks for stating the obvious, now I know what it does. -_-
Ive already disabled all the features in BIOS that would hinder overclocking (like SpeedStep) and Ive tried adjusting the voltages here and there by a tad and adjusted the ram timings to 5-5-5-15 but I cant say that I really know what Im doing.
So if anyone could please help me Id greatly appreciate it. Thanks!
Oihan
Oihan
