Need help with DFI SLI-DR mobo!
djgizmo
This is my 1st experienced my 1st no boot situation while trying to OC. I bumped the chipset voltage / ldt volts 1 notch each (think .1v) seemed to start to boot, then did the typical reboot. This time however, no video, no post... nothing. So I powered off the system, cleared cmos, then powered back on. Still nothing. Did it for 15 min. Still nothing. Left it over night. (6 hours) still nothing. Going to leave it while I'm at work, est 12 hours till I get home. I didn't pull the battery, but I guess i'll try that if this doesn't work. The on board pc speaker is enabled already.
Any other suggestions? System is in my sig.
EDIT:
Now I'm getting scared. I've just tried this (Full 6 hour clear w/ battery out) and all I get are the 4 LED lights. They are lit up from power on. I pray that I didn't fry anything.
Even tried booting w/o the video card (yes, I DID turn off all the power before removing anything) and still no beep codes. Just the 4 LED lights.
Hope the computer gods aren't trying to torture me as this could end up being my worst nightmare. I'm going to try leaving it unplugged and battery out for 24 hours and hope this works.
I've unplugged everything except my video card, cpu, 1 slot of memory (top orange slot) and power, and still same issue.
Anyone else ever have this issue with a DFI board?
You have BH/CH based memory? If yes, its typically DFI coldboot. Had this all over with my old Ultra-D and CH UTT based ram. Now im using RDX200 and BH UTT based ram without any issues.
I suggest pulling out battery, set jumper to clear cmos position, unplug your PSU from mobo, remove all ram sticks. Wait for hour, then insert battery, set jumper to normal position, turn on PSU and insert ram ir orange DIMM further from socket. Id recommend to use generic ram module to boot first time, set timigs and safe voltages, then insert your overclocking ram.
DFi nF4 is very picky with CH/BH based ram after all.
I'll try that... but the ram is (OCZ) EL ram.
but I'm not getting ANYTHING on the screen whatsoever. Not even the video card post screen.
Yeah ive had these exact same problems, except one stick will work in yellow or orange slot 100% of the time (except the week before nether worked at all), and the other wont boot, by itself or both plugged in, (its done this before), Ive had all these problems with my new SLI-DR which I received from newegg after RMAing my SLI-D (came in a SLI-D box), none of these problems came up at any time with my SLI-D and my 20 pin psu, (but the psu now isn't the problem).
That doesn't sound right, 4 LED's no boot. cold boot usualy is 3 LEDs and 1 long beep. Possible that you fried your processor?, which is weird since i run mobo and LDT at + .1v for my overclock.
Nope, fixed it. Ordered a replacement Bios chip from Tmod and voila. Working :)
