Need help with Coolermaster Cavalier case
We just got a Coolermaster Cavalier CAV T03 case and it's instruction manual should be shredded upon opening. We would like to find out how to remove the front panel and no where can I find instructions on how to do this. After awhile I decided to remove the black internal screws and pull the front off. Yay, that worked, but that should've been in the instructions.Very frustrated with the rail system too. It doesn't seem to lock well for hard drive rails in the 5 1/4 area. We need to do this to slave cd drives the way we want to and with the cables we already have. But works on cd/dvd roms well enough. Are there decent rails for harddrives out there?
The floppy drive slot is too tight to install a floppy drive without bending or pressing some of the pressed metal work outward. My BF is not going to install a floppy because it is frustrating. I would have to rate the case not very appealing to work with from the growls coming from the living room. What started as a positive project has been a pain in the butt. I can't say I would recommend this case for someone with lots of stuff to stick inside a case.
:rolleyes:
