Need help with choosing a RAID controller and Disks
Dra
Hey guys,
I'm getting ready to build my home server, and I need help choosing a discrete RAID controller and disks to go with it.
So my question is what is the best PCI-e RAID card for under $400, and what are the best 1TB disks to go with it? I've been hearing good reviews for the 3ware 9690
Also, is it absolutely necessary to use enterprise class disks with these controllers? For example, can I use something like WD Caviar Black drivers over the more expensive RE3 drives of the same capacity?
Thanks for your help!
Under $400, I can't comment. However, I have a blanket recommendation for LSI and Areca.
As to drives, you must use drives which are listed on the controller's compatibility list, period. Failure to do so can (and often does) result in unpredictable operation, problems, and potential data loss. It's not worth saving a few bucks a drive just to lose all the data. Especially at home, when you don't have tape.
