Hey guys,
I just bought a new video card ASUS HD7970 DIrectCUII.
This card requires 2x 8pin cables, the PSU i have now had only one 8pin power cable in the box, i thought buying an extra cable will fix it, but it seems that i need to replace my PSU for the video card to be fully functional.
OCZ support says: "ASUS recommends a minimum of 42 amps available on the +12V rails for the entire system. The ModXStream Pro 700W is just over that minimum with 43.75 amps. The combined power consumption of the card's two 8 pin connections is spec'd at a maximum of 25 amps which is also the max capability of of the power supply's rail that the PCIe cables are fed from."
Here are the full specs:
PSU: ModXStream Pro 700W
Motherboard: Sabertooth x79
Processor: Intel Core i7-3930K @ 3.20GHz
Video Card: Asus HD 7970 DirectCU II 3GB GDDR5
Memory: Corsair Vengeance 4x8GB DDR3 RAM
Drive: Corsair 120GB SSD
Samsung 840EVO 250GB SSD
3TB HDD
Will there be a difference in the size of the PSU?
The one i have now is 86x150x160mm, just want to make sure it's gonna fit my housing.
If anyone could help me choose the best PSU for my system, I'd be very grateful.
3TB HDD
