Diablo2K
- Aug 10, 2000
I recently started using Process Explorer and really liked it, so much more powerful than the stock Task Mananger.
Only issue I have is that I cant open it by using the menu that pops up when you hit ctrl/alt/del (CAD). right now I can open it thru a shortcut, but not thru the CAD menu or by right clicking the taskbar and selecting task manager, that now just gives me an error.
Is there some setting I can use to get it to work, perhaps a regestery setting?
