So I got 6 (yes count em 6) Intel Pent 4 Xeon's lined up to be turned into a small garden. They are all socket 603, four of them are 2.8 Ghz the other two are 3.0 Ghz.
I just need to build them out.
The board I'm thinking about is this baby here:
http://www.newegg.com/Product/Product.asp?Item=N82E16813151139
The first question, is which heat sink works with these boards?
http://www.newegg.com/Product/Product.asp?Item=N82E16835114014
http://www.newegg.com/Product/Product.asp?Item=N82E16835114022
The second question, is how much memory do I want to stick in these things? Right now my other 3 dual xeon servers (work boxen) are only using under 50 megs for all FAH clients
Memory is cheap so I'm not to concerned with cost, but more concerned with optimizing these to get most point out of them that I can. Should I try going big work units? Does that give more points, if so, what is the optimal amount of memory?
Thrid question, do you have to install DDR memory in pairs?
Anyways, that is the setup I'm going with (already have all the procs, got a great deal on them)... if you could suggest a better setup, I'm all for it. Anyone know where I could find a Quad socket 603 board? I like Tyan a lot (cause they are fucking rock solid stable)
Let me know and I'll get these up and folding for 33 shortly.
