Need help with BBA 9800Pro 128mb...
jbmx4life
Does anyone have a card like this? If so, I was wondering if someone with a DMM could check the value of a resistor on the card. The resistor is on the back of the card toward the bracket that attaches to the case. It is toward the top of the card (away from the AGP connector) and labeled "R73". I think that this is what is causing my non-boot problems.
Thanks for your help.
2.6ohms I read. Well, my DMM reads "02.6" when I set it to the "200" ohm setting. The resistor has "ZRZ" written on it. Could be 2R2, but I'm fairly sure it's a Z.
It's the same resistor as one nearby, as marked below:
FYI, the 9800pro is famous for non boot issues on certain motherboards.
Try this:
1. Unplug molex connector.
2. Turn on PC.
3. Count 2 seconds and then plug in molex while PC is on.
4. Seriously!
5. PC may well then spring into life and be fine even during soft resetting. However, next time you power off you'll have to repeat the process.
I've seen this work in many cases and done it twice myself. It's either due to a weak PSU or motherboard just has 'issues' with the card. In my friend's case who had this, simply getting a new (different) motherboard fixed it.
