bobby45512
- Oct 23, 2008
I have a foxconn cinema, you can read my review of it here http://www.newegg.com/Product/Product.aspx?Item=N82E16813186180&Tpk=foxconn cinema
Anyways, the backplate is glued on and I would like some input or ideas of taking it off. I only managed to get like the corner of the backplate loose, even then I felt like I was going to break the board.
