Need Help with Audigy
Pivo504
I have a creative audigy card & its not working right. For some reason windows7 64 bit does not recognize the drivers & creates a conflict..Also I just bought a gigabyte ga p55a & the onboard sound is not working...What is wrong, how can I troubleshoot this?
I believe Creative is still having issues with its win7 64bit drivers so you're out of luck there. As far as the onboard not working, make sure that you remove all the creative drives and the audigy card before you start trying to use it and make sure you install the lastest drivers for the chipset from Gigabytes site. http://www.gigabyte.us/
perhaps the drivers doesnt support windows 7 64bit? i had a similar issue with my sound blaster live it only supported XP so i had to buy a new sound card for vista
Well the sound is working however it doesnt sound as loud & a bit scatchy. There has to be drivers for 7
remove the audigy, problem solved.
i had a aud 2 in my system, but there is no point. most (if not all) mb sound chips are equal or better then that card.
maybe your card went bad or something. check to see if any capacitors are bulging or if one of them is blown
Is onboard sound enabled already in BIOS or does it need to be enabled? I dont see it anymore in my gigbyte ga p55a mb bios.
