NEED HELP WITH ASUS SLI PREMIUM
dantedanny
ok just finished my new build.
here it is as follows:
ASUS A8N-SLI Premium
AMD X2 4800 with a drop of Artic Silver 5
Thermaltake Extreme Venus 12 Heatsink
BFG Tech Geforce 7800GTX OC
CORSAIR XMS 2GB (2 x 1GB) DDR 400
MITSUMI Black USB2.0 & FDD Digital Card Reader
Western Digital Raptor 74GB
Western Digital Caviar SE 320GB
SONY Black 16X DVD-ROM 48X CD-ROM
PLEXTOR PX-716A/SW
CREATIVE Sound Blaster Audigy2 ZS Platinum
ASPIRE X-Superalien PS500W Blue Aluminum w/ 6 fans
DELL UltraSharp 2001FP 20.1-inch LCD WideScreen
ok i got it all up and running..with one catch. i dont want ANY raid at all. all i want is 2 hard drives with different letters. all i show is C: (which is the 74gb) i installed windows on it. i cant get the 320gb to show. it did show up when i was installing windows and i chose the 74gb drive to install windows on. it also does show up in device manager and in the bios but has no dirve letter assigned to it. how can i get access to it and assign it a letter so i can put stuff on it? also im using sata controllers and dont have jumpers set on the hard drives. should i? someone said i should try to format the 320gb drive, but how do i go about doing that at this point?
someone please help. thank you in advance
Right click My Computer and click Manage. Click on Disk Management. You can create a partition and format the drive from here.
ok i did just that, and it shows the C drive on the top half of the screen and says all is working well. on the bottom half of the screen it shows both drives but it says the 320gb is unallocated. i dont have a choice to format from this point. what should i do next?
install the western digital software and it will detect the drive and format it for you ... everything will be fine.
Install the shitty WD software!!!
right click on the unallocated drive and go to properties then create volume, its intuitive, it will prompt you to format and your done it will even ask what letter you want to use
I was just wondering on that motherboard there is a power connector. What is this connector for and is it needed? Thanks
The power connector is the Asus EZPlug you need to plug a Molex connector into it if you are using 2 video cards. Otherwise you can ignore it :)
Also do NOT use the NForce IDE drivers. My boot drive will sometimes disappear and sometimes windows won't even boot at all. Use the microsoft drivers they will save you a headache. I got this tip from a forum somewhere else. I spent my entire weekend trying to figure out why my harddrives sometimes disappear or not recognized.
