Maplehamwich
- Aug 14, 2011
Hello everyone,
So I've finally got an aftermarket cooler, two years later, and I'm looking to overclock my system.
I've done the forum search, and the google, and I've tried some overclocking. From 4.0GHz to 4.5GHz.
The issue I'm having is thermal related. I'm running a Corsair H100i and at idle I run 30-45 degrees celsius on the above overclock scale, respectively.
At load on prime 95 I run 80+ degrees celsius on the above overclock scale.
For reference I've followed this thread for settings:
http://www.overclock.net/t/1279729/intel-i7-2600k-3-4ghz-asus-p8z68-v-pro-overclock-help
Specifically, I am running these exact settings at the moment (left memory at auto):
http://www.overclock.net/t/1279729/...asus-p8z68-v-pro-overclock-help#post_17666806
Results are:
- (idle) 4.5GHz Clock; 1.344v Core Voltage; 45 degrees celsius.
- (idle) 4.0GHz Clock; 1.336v Core Voltage; 40 degrees celsius with spikes to 50...
- I previously ran an ASUS AI Suite Auto Overclock which set to the common 4.43GHz Clock; 1.34 Core Voltage and BLCK 103 and that gave me idle temps at 30-35 celsius.
- When I run everything at stock I idle at 30-35 celsius and prime 95 at 60-65 celsius.
Ambient room temperature is 20 celsius. I'm running a well ventilated Corsair Carbide Air 540 case with stock AF140L fans and an H100i with Arctic Silver 5 (pea/dot application). I've also previously run the stock thermal paste on the H100i, same thermal issues.
Any suggestions?
Results are:
Any suggestions?
