Need help with an odd reboot loop ASAP.
Maximos
Hello guys.
My uncle is having a problem with his PC - I recently formatted and fresh-installed it, then installed all normal programs...
Basically, when he boots it up, it says that your computer suffered a major hardware/software error blahblah, and then there are the standard options - the three Safe Modes and Start Normally. In any case, the computer just restarts and does the same thing. Any clue? I am completely stumped by this...
Thanks a ton guys.
Can you go into safe mode?
Sounds like a driver problem to me. My first guess is video. But with such little information provided, there really isn't much to help you with.
