Need help with an nforce 4 board
V3|!UM
Are there ANy Boards out there that support DDR400 for 2GB of ram that is double Sided? Currently the board i am using now the neo2plat does DDR100 with 1T 2-2-2-5 even if i do 3-3-3-8 i still can't even get the DDR166 the board is supposed to spec for. I got 4 sticks of the PDP patriot XBLK 1 set has the pink brain power wafer and the other doesn't.
like 4x512mb or 2x1gb...most motherboards will run 2x1gb at ddr400...but u will need a venice or san diego or x2 core to support 4x512 @ ddr400 speeds...with ur winchester u will run the 4 sticks at ddr333 because of the weaker memory controller
