cismajor97
- Mar 23, 2006
I have an RssReader.ascx control that I have pulling the latest articles and displaying them on my Default.aspx page. For some strange reason I keep getting an error on line 26. If any of the ASP.NET 2.0 guru's our there can assist me I could really use your assistance to point me in the right direction to solve this.
Here is the error:
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 24: if (value.StartsWith("/") || value.StartsWith("~/"))
Line 25: {
Line 26: url = (this.Page as BasePage).FullBaseUrl + value;
Line 27: url = url.Replace("~/", "");
Line 28: }
Source File: c:\sdalternative_v2\Controls\RssReader.ascx.cs Line: 26
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
MW.Alternative.UI.Controls.RssReader.set_RssUrl(String value) in c:\sdalternative_v2\Controls\RssReader.ascx.cs:26
ASP.default_aspx.__BuildControlRssReader1() in c:\sdalternative_v2\Default.aspx:5
ASP.default_aspx.__BuildControlContent1(Control __ctrl) in c:\sdalternative_v2\Default.aspx:4
System.Web.UI.CompiledTemplateBuilder.InstantiateIn(Control container) +32
ASP.alternative_master.__BuildControlMainContent() in c:\sdalternative_v2\Alternative.master:170
ASP.alternative_master.__BuildControlMain() in c:\sdalternative_v2\Alternative.master:41
ASP.alternative_master.__BuildControlTree(alternative_master __ctrl) in c:\sdalternative_v2\Alternative.master:1
ASP.alternative_master.FrameworkInitialize() in c:\sdalternative_v2\Alternative.master.cs:912307
System.Web.UI.UserControl.InitializeAsUserControlInternal() +46
System.Web.UI.UserControl.InitializeAsUserControl(Page page) +35
System.Web.UI.MasterPage.CreateMaster(TemplateControl owner, HttpContext context, VirtualPath masterPageFile, IDictionary contentTemplateCollection) +1206
System.Web.UI.Page.get_Master() +72
System.Web.UI.Page.ApplyMasterPage() +30
System.Web.UI.Page.PerformPreInit() +48
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1446
Here is the error:
Source Error:
Line 25: {
Line 28: }
Stack Trace:
Code:
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Xml;
using MW.Alternative.UI;
namespace MW.Alternative.UI.Controls
public partial class RssReader : System.Web.UI.UserControl
public string RssUrl
get { return lnkRss.NavigateUrl; }
set
string url = value;
lnkRss.NavigateUrl = url;
public string Title
get { return lblTitle.Text; }
set { lblTitle.Text = value; }
public int RepeatColumns
get { return dlstRss.RepeatColumns; }
set { dlstRss.RepeatColumns = value; }
public string MoreUrl
get { return lnkMore.NavigateUrl; }
set { lnkMore.NavigateUrl = value; }
public string MoreText
get { return lnkMore.Text; }
set { lnkMore.Text = value; }
protected void Page_Load(object sender, EventArgs e)
try
if (this.RssUrl.Length == 0)
throw new ApplicationException("The RssUrl cannot be null.");
// create a DataTable and fill it with the RSS data,
// then bind it to the Repeater control
XmlDataDocument feed = new XmlDataDocument();
feed.Load(this.RssUrl);
XmlNodeList posts = feed.GetElementsByTagName("item");
DataTable table = new DataTable("Feed");
table.Columns.Add("Title", typeof(string));
table.Columns.Add("Description", typeof(string));
table.Columns.Add("Link", typeof(string));
table.Columns.Add("PubDate", typeof(DateTime));
foreach (XmlNode post in posts)
DataRow row = table.NewRow();
row["Title"] = post["title"].InnerText;
row["Description"] = post["description"].InnerText;
row["Link"] = post["link"].InnerText;
row["PubDate"] = post["pubDate"].InnerText;
table.Rows.Add(row);
dlstRss.DataSource = table;
dlstRss.DataBind();
catch (Exception)
this.Visible = true;
