Need help with a Sophos UTM
Looking for some advice on setting up nat rules on my Sophos utm.
I have a synology box running behind the utm and an unable to upload photos from the iPhone apps both internally and externally.
By default Sophos blocks all outgoing ports so you need to make sure that whatever port the NAS is trying to communicate on is allowed out. I don't use that function on my synology but i had the same problem with my nest and philips hue lights when i setup my sophos UTM.
Also check your application filtering/web filtering rules. Application filtering will remove a lot of sites and programs.
Oh yes don't forget that especially if you enable web filtering. I had to add rules in for netflix and a couple of devices like the roku and wd live tv before it would work correctly.
