Hard and Confused
- Sep 13, 2008
Okay, I'm trying to help a friend get his $90 outta the XP home he purchased from the Egg for his Pavilion a6303w and so far I've found that you need to make a slipstream CD with the G33 chipset drivers to stop the BSOD's during install.
From what I have gathered thus far its easiest to use an SP2 disk to make the slipstream files but the one he bought was the SP3B disk so I DL'd an XP Home SP2.iso and also I got the latest nLite but to this point I'm having no luck getting the friggen G33 drivers to install either using his SP3B disk or the SP2.iso I dl'd.
So far the slipstream CD's I've made with the SP2 and SP3B media are causing BSOD's in the same place so I'm thinking maybe I'm using the wrong driver files?
I have winrar and was unable to extract the files from the G3 installer so instead I launched the .exe and let it put the files in the system32/temp folder then I coppied the 4 folders from there which were " IPMx2 , IPMx4 , IPMx5 and IPMx6 ". The files I think I need are in the folder "ALL " in IPMx2 " as thats the only one that has .inf files in it.
Does anyone know if I'm using the right files for the G33 chipset drivers or am I making some sorta mistake somewhere else ?
If anyone needs more info I can provide it but TBH this is my first time slipstreaming an OS cd so I'm kinda clueless but I did spend the last day googling my ass off and I think I'm doing everything right but maybe I'm missing a step or using the wrong media somewhere.
