Engine of End
- Jul 5, 2006
Hello,
Long time lurker, first time poster here, and I need some help planning my future water cooling rig (my first I might add).
So far, I have decided to use the following:
Black Ice GT Stealth 240 (2x120mm)
Swiftech MCRES-MICRO Hi-Flo Reservoir
Swiftech MCP655 12 VDC Pump
Storm Water-block
1/2" ID tubing
As for the case, I absolutely love Antec's P180. Although, I am rather picky about where the radiator goes. I didn't want to have it hanging on the back of the case (or external for that matter). Lo and behold, someone sells a P180 that is ready for water-cooling. This is what I have chosen.
Now comes the part where I need help. I still want to use fans in the case, and I have chosen these. Besides using them as case fans (hooked up to a controller), I want to know if I can use them as fans for the radiator. They have a maximum CFM of 110, so it seems they can get the job done.
What I also need help with is air flow. Since I couldn't find a picture of the inside of Performance PC's P180, I used a stock one. This is what I want to do (imagine the top two arrows being the fans for the radiator):
What I thought of doing was removing the top hard drive bay and putting the reservoir there, that way one of the FM121's can cool it. The other two FM121's would go in the top left corner. Since I would have all this cool air flowing into the case, I would have the fans for the radiator suck the air out, thus cooling it. The bottom fan for the PSU will be left alone.
So what do you think? I am open to all suggestions.
Storm Water-block
1/2" ID tubing
