Need help with a new motherboard selection
jaSihr
My Epox 8RDA3+pro has failed on me. Its less than a year old, but has been trouble since day one. I've decided to try to step up to a better board. The problem is I only have about $150 to spend on my upgrade and that is all I'm likely to be able to spend this year. I've checked all my other components and fortunately they still work. I have a matched pair of Mushkin 2-2-2 special PC3200 (2X512MB) and (2X512MB) Corsair TwinX PC3200, also a matched pair. For video I have a Biostar SigmaGate 6800XT 512MB AGP. For power I have an Enermax Whisper EG365P-VE 20 pin ATX. Finally a WD2000JB ATA133 hard drive. What I want is a motherboard/CPU combo that will at least match the performance of my mobile Barton/nForce2 400 ultra setup. Since I have so little to spend, I'll probably need something in which I will be able to use my current memory and video card. I'd like to have something that is a fairly good overclocker. I was thinking maybe a socket 754 or 939 combo. I will even consider an Intel combo. The problem is there are so few AGP/DDR motherboards left at Newegg. I'm not interested in buying from an individual or on Ebay. I'm way too poor to take the chance. I might consider a refurbished board from a reputable dealer. The most demanding application I run is Half-Life2: Episode One. Any suggestions you guys can make for a retail AGP/DDR motherboard would be greatly appreciated. Thanks in advance for any help you can give.
