Need help with a Laserjet 6L problem
erehwon6811
We got two of these sitting in our upstairs room that are not functional right now. I would like to find out if I can fix them or if I should just get rid of them.
Printer one - My brother picked this one up from a garage sale a few years ago for $10. It worked for several years. It is no longer working correctly. My brother said it was grabbing multiple sheets at the same time and something else.
Printer two - I got this one from a garage sale for free. The lady wanted to get rid of it since it was broken. Said her husband had tried to repair it and might not have gotten it back together completely. I haven't tested this one. I think it was doing the same thing as printer one.
If you guys can help or lead me to some good information guides, I'd appreciate it.
The HP laserjet 5L, 6L, 1100se, etc. all suffer from the multiple paper grab issue. You can clean the roller/paper grabber thing and it helps a bit. Also, I've found that keeping a lot of paper in the printer helps too. But basically, these printers are just very poorly designed.
There's a fix kit available but I haven't tried it:
http://www.fixyourownprinter.com/kits/hp/K30
(that site also has some decent info if you look around)
HP actually had some sort of a recall sort of thing with these printers a while ago where they mailed you some thing that you cram down in the printer that was supposed to fix the issue. I'm not sure if that's still in effect or not.
The "L" and "P" series printers of that generation frequently suffered from the feed problems you described. I can't even count how many of those I fixed during that time. 90% of the printers were fixed by replacing the feed rollers and seperator pads.
Any HP shop can repair it for around $75.
You really need to be more specific with the issues. Saying there is a paper feed issue "and something else" doesn't give us much to work with. I also can't suggest anything on the second printer when you haven't even tested it to see what is wrong.
Sorry I can't be more specific. On the first one, I'm just reporting what a family member said to me half a year ago. The second one I should get around to testing soon.
I did not want to come off sounding harsh, but there are a lot of smart people here that can give you great answers if you can be more detailed.
I've had the 5L/6L printers in the past. Got them from work. They are known for the first issue you describe. There was a big class action lawsuite against HP for this. At one time, HP would send you the repair kit for free. A cardboard "tool" that you used to install a rubber pad thing down inside near the rollers. I watched our printer repair dude open and use those kits over and over again. It helped a lot, but would still occasionaly pull too much paper. If you could find one of these kits for free or less than $10 bucks, and you had a good toner, it might be worth messing with. If you have to spend $75 or more to get that working, I personally wouldn't waste my time with it.
