LKilmister
- Jan 23, 2017
Hello,
I am looking for a couple of old laptops that still have some power to them and are fairly cheap. I saw some lenovo x220s with I7 processors, but even on ebay they are a bit much.
I know I'm asking a lot, but here's what I want to use them for. I need two or maybe three of them for myself and my brothers. We are trying to learn how to program with python, javascript, java object oriented programming via Udacity nano degrees.
We need the laptops to be able to handle the requirements to run the programs that will be needed for these classes. We will also be doing some lite photo editing/vector art for web design using affinity photo and affinity designer. I'd like to keep the total cost as low as possible, my budget is $500. 4 gigs of ram is suggested as a minimum from what I've read and I am totally basing what I'm looking for on the processor (i7).
I am not stuck on lenovo, but it just seemed like the most powerful laptop I could find for the price, but most do not hard drives. i considered Chrome books, but I will not always be working with an internet connection so I don't think it would be a good option for me.
Thanks for any help/advice you can give
