Gaming, MMO's, RTS, DOTA 2, and for FPS I really only touch BF3 or CS(45% of the time and droping), but I also build with future plans in mind so I need to be able to render still pictures no animation, and ALOT of photoshop and programming, and light video editing. Also I may or will be running Virtual Environments so VMware included
$2800-$4000(getting parts overtime)
U.S.A. Southern California
Issue with CPU(LGA 2011 only) and RAM
not reusuing but keeping the old 4870 has a backup GPU.
6) Will you be overclocking?
no, I build to last and I usually upgrade every 3.5 to 5 years, so this build have to last till 2017,2018(not the video card of course but the cpu must) or when intel's skymount chipset is released(so you know it goes skylake "tick" then skymount "tock")
7) 7) What is the max resolution of your monitor? What size is it?
1900x1200
parts over time, hope to be done by the end of the year.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
UEFI(a must)
RAID
crossfire or SLI
USB 3.0
SATA 6gb/s
Note: I will be cashing two 1TB with 30GB SSD for a bit of a speed boost, booting from 120gb SSD and using 2tb HDD for storage
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Vista 64-Bit, will buy windows 8 and will be using Linux OS
Truthfully I have a general Idea of what I want so its question #1, #4 that I need answers too(CPU and RAM). would the 3930K be enough or should I go the Xeon route for dual CPU for rendering still pictures?
1900x1200
UEFI(a must)
RAID
crossfire or SLI
USB 3.0
SATA 6gb/s
