Need help with a CRT...
donkey33
Upgraded my GeForce 4 MX 440 to an FX 5900 XT.
My 17" CRT only supports 1280x1024 though and I think I can go higher with the 5900 so I suppose it's time to get a new one.
Can monitors be purchased directly from suppliers. I'm in Australia and got recommended the Samsung SyncMaster955DF-T/T on the net but can't find it anywhere in shops around here.
If that can't be found, what are some other good CRT's that will supports a higher resolution. Also, I'd be looking for a 19".
Thanks
