Need help with a build
at_viper
I am rebuilding an old Gateway essential from 1998. The only things I am using is the case, cd drive and the power supply. I just purchased a mobo and cpu from here and I have a 40 gig hard drive that i know works. I push the power button the cpu fan spins up but the hard drive doesnt spin and neither does the cd drive. I am running both the cd drive and the HD off one ide cable being that I have only one channel on the mobo. Also the power supply is old it has a 20 pin connector that is it. There is no separate 4 pin connect to plug into the mobo. I am at a lose for what to do. Any help would be great.
OK HERES THE THING. THE CPU COULD BE BAD. I THREW IN AN IDE CONTROLLER AND THE HARD DRIVE SPINS UP TRIED NUMEROUS HD'S HOWEVER, THE CD DRIVE STILL DOESNT OPEN LIKE THERE IS NO POWER BUT IT IS CONNECTED AND I KNOW THE POWER SUPPLY IS GOOD. (BC THE HD SPINS UP) THE MONITOR JUST FLASHES AS IF IT WAS GETTING NO INPUT. PLEASE TELL ME WHAT YOU THINKG
