NEED HELP! Windows 7 and new built.
nyererei
Hi, I'm a newb, here's my problem;
I just built a new computer, with a Asus P5QL Pro motherboard. And I did a fresh install with Windows 7 beta 64 bit. Everything installed and booted fine. But when I inserted the CD that came with the motherboard to install the drivers, a window pops up saying that the "motherboard support cd does not support this system". So I can't install my network adapter to get on the internet etc.
Is there anyway around this? Would installing windows 7 beta 32bit work?
Thanks in advance.
Windows didn't install a NIC driver on its own? Most newer systems I've seen had drivers load automatically post-install.
Also, never use the drivers on the included CD. Download the latest ones from the appropriate websites.
And to be honest, I wouldn't go right for a Windows 7 install on a brand-new system. Just me, though.
Win7 64bit will work fine. Just browse to the driver, copy it to your desktop, set it to compatability mode with Windows Vista, and install (its an Atheros driver, right? My P5Q works fine in Win7.)
ASUS us just doing a OS version check, and if it != WinXP/Vista/Server2003/whatever, they shit on you. Sigh. Why can't people just query the version number, if(versionNumber >= 6000)...
Win7 doesn't support the Atheros driver on P5Qs AFAIK. It happens...they can't merge EVERY driver into the OS, lest the OS installer grow to take up multiple install DVDs.
Download the Vista x64 drivers for your system on a flash drive. You should always do this before installing an OS on a system, in case you can't get to the internet for the drivers afterwards.
@rampantandroidt
THANK YOU VERY MUCH!! That worked perfectly. Hardforum is an awesome place to get help. Posted problem on hardforum, ten minutes later, problem solved :).
Thanks again.
