Need help. Win2k install killing HDs?
Devnull
Does this make any sense to anyone?
Setup:
Abit NF7-S
Athlon XP Barton 2500+
Kingston HyperX PC3200 CL2 512MB
350W PSU(unknown brand that came with case, had been using my enermax but its in my newer rig now).
GeForce2(also swapped good video card into new rig)
WD SE 120GB IDE (Win 2K SP3)
WD SE 250 GB SATA (WinXP)
Maxtor storage drive 250GB IDE(unreadable)
Firstly this is not my current rig, but I sitll have a lot of important stuff on both my WD drives.
So backtrack to many months ago(and I maybe have posted it on here)... I had been using the WD SE 250GB as my OS drive, and the Maxtor for some misc storage. I had some program that was installed on my older drive with Win2k on it and booted over there to use it. At that time I also copied/deleted/moved some files that were on my Maxtor drive. Then after rebooting in to XP the maxtor storage drive became unreadable.
I had asked around about this and thought it over on my own and dedicded it was just an odd occurance. Never got the maxtor readable, but it just needs a format as far as I can tell, and nothing on there I'd really miss... Just been too busy and not in terrible need of the space until now.
So tonight I was going to see what's on the maxtor if I wanted to recover anything from it. So I boot into 2k and run R-Studio on the Maxtor and find it really only has some DVD stuff I was working on. So I delete a few large files from my 250GB WD SE to make space for a recovery of some DVD stuff, to be then recopied over to the maxtor later.
However when I tried to boot into WinXP on my 250GB SATA WD drive, it wanted to run CHKDSK on my 120GB drive and it found no errors, but then it got a BSOD and rebooted before I could see any kind of message.
Tried it a few times and could not get it to boot into windows and it just rebooted before I could see the BSOD error. If I try booting into safe mode it will just sit there for 5+ minutes with hard drive activity but not going into windows. I removed the hard drive from the computer and hooked it up to my new rig. It showed up ok under my computer with a drive letter and I ran chkdsk on it, correcting some errors.
After hooking it back up to my old machine, I have the exact same problem. At this point I tried a repair install of windows, figuring the install may have been damaged... As soon as it got done with the first part where it's copying files and needs to reboot to start the actual install I get the BSOD again upon reboot.
Is there likely some kind of file table damage? I think I can recover the files by hooking it up to my new rig again, but I'd rather just try to fix the partition if thats the problem. How the heck is using other drives under the win2k OS causing these problems? I'm off to bed so I can get a clean start on this tomorrow but I appreciate any ideas. Thanks
I'd check the boot order in the bios and the jumpers on the drive to make sure they aren't on cable select as this sometimes causes problems.
edit: new log posted, posted an incorrect, older one previously.
I think the problem is 48-bit LBA...
I thought it was enabled in 2k, since I have the latest SP. However it wasn't enabled in the registry :(
So I hope I will be able to recover my stuff. What I did when accessing the drive was delete about 30GB of dvd related files I had been working on but no longer need. I sure hope my data didn't get overwritten somehow and hope its some kind of MBR/Boot Sector/Partition table problem.
Here is a diskpatch log if anyone is familar with it.
.../000:21/LOG> ### LOG START ###
.../000:21/LOG> DISKPATCH 2.1.100
.../000:21/LOG> (C) 2000-2005, DIY DataRecovery
.../000:21/LOG> Contact info: HTTP://www.DIYDataRecovery.nl
.../000:21/LOG> DPRunType: 0
.../000:21/LOG> DPUsrName: DEMO
.../000:21/LOG> MemFree: 107Kb
.../000:21/LOG> LogDate: 11-02-2005
.../000:21/CFG> Dump Options requested
.../000:21/CFG> FilePath="1/.\DP_FILES\"
.../000:21/CFG> LogFilename="DP.LOG"
.../000:21/CFG> ReadRetries="32"
.../000:21/CFG> MaxReadErrors="32"
.../000:21/CFG> ReadDelay="1"
.../000:21/CFG> AutoSaveState="1"
.../000:21/CFG> DumpFoundSectors="0"
.../000:21/CFG> LogLevel="2"
.../000:21/CFG> DebugLevel="0"
.../000:21/CFG> MaxFatScan="51200"
.../000:21/CFG> MaxDataColEntries="512"
.../000:21/CFG> ScanType="0"
.../000:21/CFG> IgnoreF8FF="0"
.../000:21/CFG> ScanSignature="55AA"
.../000:21/13H> Ext13H installed test requested
.../000:21/13H> Disk found at 128
.../000:21/13H> Ext13H version: 2.1 / EDD-1.1
.../000:21/13H> Ext13H Support: Extended disk access functions
.../000:21/13H> Ext13H Support: Enhanced disk drive functions
.../000:21/13H> Disk 128 X13H data : 16383/16/63 234441648/512
.../000:21/13H> Disk found at 129
.../000:21/13H> Ext13H Flags: DMA boundary errors handled transparently
.../000:21/13H> Disk 129 X13H data : 16383/255/63 488397168/512
.../000:21/13H> Ext13H tested ok
.../000:21/FDL> DiskList requested
.../000:21/FDL> Disk found at 128
.../000:21/FDL> Disk found at 129
.../000:21/LOG> Dump DiskList requested
### DISKLIST.ARRAY ###
__D_|________LBA_|___H_|__S_|__GB
128 | .234441648 | 255 | 63 | 111
129 | .488397168 | 255 | 63 | 232
..0 | .........0 | ..0 | .0 | ..0
.../000:21/IAS> Admi Sector found on disk 0 (128)
.../000:21/IAS> Admi Sector found on disk 1 (129)
.../000:21/EXE> FingerPrint found
.../000:21/PFC> PQstuff signature not detected on disk 0 (128)
.../000:22/PFC> PQstuff signature not detected on disk 1 (129)
.../000:22/PFC> Partition State Backup not found on disk 0 (128)
.../000:22/PFC> Partition State Backup not found on disk 1 (129)
.../000:25/MNU> - Main, Select Disk
.../000:39/USD> Disk 1 (129) selected
.../000:39/USD> Read/WriteErrors reset to 0
.../000:39/USD> DataCollection / PartList cleared
.../000:39/GSC> No Geo change detected for Disk 1 (129)
.../000:39/GSC> Geo for Disk 1 (129) saved as 0488397168255063
129/000:40/LOG> Dump MBR requested
### MBR FOR DISK 129
000 90 E9 7D 01 FA 33 C0 8E D0 8E C0 8E D8 BC 00 7C | ?é}.ú3ÀŽÐŽÀŽØ¼.|
016 8B F4 FB BF 00 06 B9 00 01 F3 A5 BB 20 06 FF E3 | ‹ôû¿..¹..ó¥» ..ã
032 90 90 BE 7D 07 81 3C AA 55 75 11 E8 58 00 73 0C | ??¾}.?<ªUu.èX.s.
048 E8 65 00 72 07 E8 B1 00 72 3B EB 2C BE 7D 07 C7 | èe.r.è±.r;ë,¾}.Ç
064 04 00 00 BA 80 00 BE BE 07 B9 04 00 F6 04 80 75 | ...º€.¾¾.¹..ö.€u
080 07 83 C6 10 E2 F6 EB 1D 8A 74 01 8B 4C 02 BB 00 | .&#402;Æ.âöë.&#352;t.&#8249;L.».
096 7C B8 01 02 CD 13 72 0D 81 3E FE 7D 55 AA 75 05 | |¸..Í.r.?>þ}Uªu.
112 EA 00 7C 00 00 BE 6A 07 AC 0A C0 74 FE BB 07 00 | ê.|..¾j.¬.Àtþ»..
128 B4 0E CD 10 EB F2 BB 00 7E C6 07 13 C6 47 01 00 | ´.Í.ëò».~Æ..ÆG..
144 B2 80 B8 00 E0 CD 13 C3 BF 00 7E BA F0 01 B3 A0 | ²€¸.àÍ.ÿ.~ºð.³!
160 E8 84 00 72 0C B1 01 E8 48 00 72 05 E8 19 00 73 | è&#8222;.r.±.èH.r.è..s
176 16 F6 C3 10 75 05 80 CB 10 EB E5 81 FA 70 01 74 | .öÃ.u.€Ë.ëå?úp.t
192 05 BA 70 01 EB D8 F9 C3 81 BD FE 01 55 AA 75 17 | .ºp.ëØùÃ?½þ.Uªu.
208 8B 75 02 81 FE BE 01 77 0E 03 F7 81 3C AA 55 75 | &#8249;u.?þ¾.w..÷?<ªUu
224 06 F6 44 02 01 75 01 F9 C3 BF 00 7C B1 0A E8 01 | .öD..u.ùÿ.|±.è.
240 00 C3 52 57 83 C2 02 B0 01 EE 42 8A C1 EE 42 32 | .ÃRW&#402;Â.°.îB&#352;ÁîB2
256 C0 EE 42 EE 42 8A C3 EE 42 B0 20 EE E8 33 00 EC | ÀîBîB&#352;ÃîB° îè3.ì
272 24 FD 3C 58 75 0D 83 EA 07 B9 00 01 FA F3 6D FB | $ý<Xu.&#402;ê.¹..úómû
288 F8 EB 01 F9 5F 5A C3 52 83 C2 07 EC A8 80 75 0F | øë.ù_ZÃR&#402;Â.쨀u.
304 4A 8A C3 EE 42 EC 24 D0 3C 50 75 03 F8 EB 01 F9 | J&#352;ÃîBì$Ð<Pu.øë.ù
320 5A C3 51 8B 0E 6C 04 83 C1 12 81 C2 FF 01 EC 8A | ZÃQ&#8249;.l.&#402;Á.?Â..ì&#352;
336 E0 80 E4 D8 80 FC 58 74 06 3B 0E 6C 04 75 EF 81 | à€ä؀üXt.;.l.uï?
352 EA FF 01 B9 00 20 E2 FE 59 C3 0D 0A 45 72 72 6F | ê..¹. âþYÃ..Erro
368 72 20 4C 6F 61 64 69 6E 67 20 4F 53 00 AA 55 00 | r Loading OS.ªU.
384 00 E9 80 FE 00 00 00 00 00 00 00 00 00 00 00 00 | .é€þ............
400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
416 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
432 00 00 00 00 00 00 00 00 8B 2A D1 10 00 00 80 01 | ........&#8249;*Ñ...€.
448 01 00 07 FE BF C0 3F 00 00 00 42 45 1C 1D 00 00 | ...þ¿À?...BE....
464 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
496 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA | ..............Uª
### Interpreted Partition Table Information
### _ACT_|_TYPE_|__START--C/H/S_|__END----C/H/S_|__LBA-start_|_LBA-length
..1 .128 | ..07 | ....0...1...1 | ..704.254..63 | ........63 | .488392002
..2 ...0 | ..00 | ....0...0...0 | ....0...0...0 | .........0 | .........0
..3 ...0 | ..00 | ....0...0...0 | ....0...0...0 | .........0 | .........0
..4 ...0 | ..00 | ....0...0...0 | ....0...0...0 | .........0 | .........0
129/000:55/MNU> - Main, Disk Ops
129/000:59/MNU> - Main, Options
129/001:07/CFG> Dump Options requested
129/001:07/CFG> FilePath="1/.\DP_FILES\"
129/001:08/CFG> LogFilename="DP.LOG"
129/001:08/CFG> ReadRetries="32"
129/001:08/CFG> MaxReadErrors="32"
129/001:08/CFG> ReadDelay="1"
129/001:08/CFG> AutoSaveState="1"
129/001:08/CFG> DumpFoundSectors="0"
129/001:08/CFG> LogLevel="2"
129/001:08/CFG> DebugLevel="0"
129/001:08/CFG> MaxFatScan="51200"
129/001:08/CFG> MaxDataColEntries="512"
129/001:08/CFG> ScanType="0"
129/001:08/CFG> IgnoreF8FF="0"
129/001:08/CFG> ScanSignature="55AA"
129/001:10/MNU> - Support, Analyze Disk / StateFile (no repair, create log)
129/001:11/SCN> DiskScan requested, ScanType is 0
129/001:11/SCN> DiskScan 0 (0 0 1) / 488397167 (30401 80 63) / 488397168
129/001:11/SCN> First bunnyhop BS at 63 (0 1 1)
129/001:11/SCN> Next bunnyhop BS at 488392065 (30401 0 1)
129/019:44/SCN> Next bunnyhop BS at 488392065 (30401 0 1)
129/019:44/SCN> DiskScan completed
129/019:44/SCN> ReadErrors for disk 1 (129): 0
129/019:44/SST> SaveState requested for disk 1 (129)
129/019:49/SST> SaveState finished for disk 1 (129)
129/019:50/CDC> CleanDatacollection requested
129/019:50/CDC> DataCollection Items found: 12
129/019:50/CDC> DataCollection Items flagged: 3
129/019:50/CDC> CleanDatacollection finished
129/019:50/LOG> Dump DataCollection requested
129/019:50/LOG> DataCollection Items found: 12 / 3
### DATACOLLECTION.ARRAY, FULL ###
SEQ_|___D_|________LOC_|____TYPE_|__COM_|______START_|_____LENGTH_|__PL_|_F
001 | 129 | .........0 | ...NTFS | PTE1 | ........63 | .488392002 | PRI | .
002 | 129 | .........8 | ...NTFS | PTE1 | ........71 | .488392002 | LOG | I
003 | 129 | ........63 | ...NTFS | ..BS | ........63 | .488392002 | PRI | .
004 | 129 | ........63 | ...NTFS | ..BS | ........63 | .488392002 | PRI | I
005 | 129 | ..33784756 | ..FAT16 | PTE1 | .639084488 | 1919025152 | LOG | .
006 | 129 | .132439945 | LINUX S | PTE3 | 1932676424 | 4278213323 | LOG | .
007 | 129 | .137339767 | EZDRIVE | PTE4 | 1564058657 | ....524458 | LOG | .
008 | 129 | .137339772 | EZDRIVE | PTE1 | .137339942 | 2852629077 | LOG | .
009 | 129 | .137339777 | EZDRIVE | PTE4 | 1564058667 | ....524458 | LOG | .
010 | 129 | .463844853 | ...NTFS | PTE1 | .463844916 | .488392002 | LOG | .
011 | 129 | .488392064 | ...NTFS | .BBS | ........63 | .488392002 | PRI | .
012 | 129 | .488392064 | ...NTFS | .BBS | ........63 | .488392002 | PRI | I
### DATACOLLECTION.ARRAY, CLEANED ###
129/019:50/MPL> MakePartList requested
129/019:50/MPL> MakePartList Items created: 7
129/019:50/MPL> MakePartList finished
129/019:50/LOG> Dump PartList requested
129/019:50/LOG> PartList Items created: 7
### PARTLIST.ARRAY ###
SEQ_|____TYPE_|_PTE_|__BS_|_BBS_|F8FF_|___S_|___L_|__PL_|_C_|___R
001 | ...NTFS | ..1 | ..3 | .11 | --- | ..1 | ..1 | ..1 | 3 | .7#
002 | EZDRIVE | ..8 | --- | --- | --- | ..8 | ..8 | ..8 | 1 | N/A
003 | ...NTFS | .10 | ... | ... | --- | .10 | .10 | .10 | 1 | .1-
004 | ..FAT16 | ..5 | ... | --- | ... | ..5 | ..5 | ..5 | 1 | .1-
005 | EZDRIVE | ..7 | --- | --- | --- | ..7 | ..7 | ..7 | 1 | N/A
006 | EZDRIVE | ..9 | --- | --- | --- | ..9 | ..9 | ..9 | 1 | N/A
007 | LINUX S | ..6 | --- | --- | --- | ..6 | ..6 | ..6 | 1 | N/A
### PARTLIST.ARRAY.INTERPRETED ###
SEQ_|____TYPE_|______START_|_____LENGTH_|________END_|__PL_|___R
001 | ...NTFS | ........63 | .488392002 | .488392064 | PRI | .7#
002 | EZDRIVE | .137339942 | 2852629077 | 2989969018 | LOG | N/A
003 | ...NTFS | .463844916 | .488392002 | .952236917 | LOG | .1-
004 | ..FAT16 | .639084488 | 1919025152 | 2558109639 | LOG | .1-
005 | EZDRIVE | 1564058657 | ....524458 | 1564583114 | LOG | N/A
006 | EZDRIVE | 1564058667 | ....524458 | 1564583124 | LOG | N/A
007 | LINUX S | 1932676424 | 4278213323 | 6210889746 | LOG | N/A
129/019:50/VEC> Start Verify EPBR Chain for disk 1 (129)
129/019:50/VEC> MBR: 55AA found, Valid Type F/5 not found
129/019:50/VEC> Partition Table info for sector 0 (0 0 1)
129/019:50/LOG> PartListDump requested at 0 (0 0 1)
129/019:50/LOG> BootSectorDump requested at 63 (0 1 1)
### BootSectorDump for BStype NTFS
...........Jump Code (hex): EB5290
............OEM Name (txt): NTFS
....Bytes per Sector (dec): 512
.Sectors per Cluster (dec): 8
....Reserved Sectors (dec): 0
..............Unused (hex): 0000000000
....Media Descriptor (hex): F8
...Sectors per Track (dec): 63
.....Heads per Track (dec): 255
......Hidden Sectors (dec): 63
.............Unknown (hex): 00800080
.......Total Sectors (dec): 488392001
........MFT Location (dec): 4
.MFT Mirror Location (dec): 30524500
....Clusters per FRS (dec): 246
.Clusters/Indx Block (dec): 1
...........Volume ID (hex): 01C445EAE1826720
........Volume Label (txt): 2502
............Checksum (hex): 00000000
....Sector Signature (hex): AA55
129/019:50/VEC> Verify EPBR Chain finished
129/019:50/EXE> Analysis Complete
129/020:04/MNU> - Main, MBR ops
129/020:09/MNU> - Main, Tools
129/020:12/MNU> - Main, Analyze Disk / StateFile
129/020:14/EXE> Analysis aborted
129/020:16/MNU> - Main, Analyze Disk / StateFile
129/020:20/EXE> Analysis aborted
129/020:25/MNU> - Main, Quit
129/020:25/LOG> RunTime: 020:25
129/020:25/LOG> ### CLOSE LOG ###
I will check the jumpers, but im pretty sure 48-bit LBA caused this :(
