SomeGuy133
- Apr 12, 2015
So i got a Yoga 700 for my trip and it has Win 10. I know now how to remove all the BS in 7 that makes it slow. How do i remove all that transition crap in 10?
already removed lenovo preload stuff.It might help to get an idea of how much extra stuff Lenovo is preloading.
interesting. Do you have a source for the media for install?You just need clean install media. Since the machine has already been activated with 10, the key is stored with Microsoft associated with its hardware configuration. You shouldn't even be asked for a key during install, and if you are choose "skip" or whatever the option is and it will activate automatically once it's online.
The easiest way to remove bloat ware is to just re Install w10 from a clean media iso/usb. Since it was already actiavted, no key is needed.
Then in order to remove the bloat from vanilla windows 10, there are many "spy removal" or privacy apps. I'm on mobile or I'd link them.
I am talking about all the BS transitions (fades, swooping, and so on).
The spyware removal would be nice too.
How can i clean install a laptop with an oem key?
Does the standard retail key that is already stored and activated just work per the usual?It is better to use a purged ISO like the Privacy Edition of W10 NTSB Enterprise...that is available via your favorite Linux ISO distributor.
W10 has a gigabyte+ of crap you cannot remove in OS.
is where is that?It is better to use a purged ISO like the Privacy Edition of W10 NTSB Enterprise...that is available via your favorite Linux ISO distributor.
"No matter what I do." What have you tried? When it starts to boot you can mash the F12 key to enter the boot menu and select a device to boot from. If the USB drive doesn't show up as a bootable device you might have to either set the boot flag using fdisk or similar utility, or reformat the drive partition to be bootable.so yea i cant get the yoga 700 to boot froma usb no matter what i do.
dont have dropbox set up yet on phone. I can post photos alter but i have fast boot off, enabled usb boot, and have usb first...all 3 of them at that.
any ideas guys?F12 does nto work. you push a side button and it opens a menu where u select bios or boot order.
Dropbox - Yoga 700 BIOS
everything u see there i have tried. It still always boots to desktop.
EDIT yea i just doubled checked and the usb install media does work on another computer so it is the Y700 not booting off the usb drive.
Had to double check that of course That would be a silly user error to use a bad usb drive but a last it is something wrong with boot menu
any ideas guys?
didn't try the hybrid sleep thing. I due shut down and its fully powered off and I go into BIOS and restart from BIOS and that doesn't work so it shouldn't be still in hybrid sleep but i can try it later. Its now too late for me to really figure this all out before my trip so i'll just have to stick with default lenovo windows.Just skimmed the thread so pardon if it was suggested, but have you tried disabling hybrid sleep/fast startup? Fast Startup - Turn On or Off in Windows 10
Have you located the 'novo' little round button? Have you tried punching it like a speedball all the way from turn on to 'loading windows'?
novo button? you mean the button to go into bios?
K noted. If i somehow have time before i leave i'll try itYeah, the little 'go to bios' one. Laptop vendors all seem to have a special button of their own
I had the boot issue and bios setup issue with hybrid sleep enabled with 8 and 8.1 on some Lenovo, so I'm guessing that's your culprit.
only has 3.0 slots and i used MS website for the creation so not sure what yumi is.
Well i dont have anymore time to deal with it so whatever...stupid lenovo.
yea but if it doesn't work already how is yumi going to help?If you have an ISO of the media, Yumi is a way to have a bootable thumbdrive with a nice menu so you can choose what to boot.
interesting. noted. I wont have time to mess with laptop but i'll keep it in mind in the futureWell, it may contain better bootstrap code. Sort of like... an outdated Windows Installer can't sometimes detect your HDD but a newer Installer does (because it's more robust).
And as a bonus, Yumi lets you have a thumbdrive with multiple Installers and Bootable Toolkits like Hiren
