Need help w/ watercooling
endorphins
Hey,
It's about time I upgrade my pc again, and this year I'm deciding on buying the following:
Asus P5N32-E SLI 680i Motherboard
Intel Core 2 Duo Conroe E6750 2.66ghz (plan to take overclock it to 3.0ghz or higher)
I'll be keeping:
Nvidia GeForce 7900GTX 512mb gfx card
2 74GB WD Raptor HDD's Raid-0
1 200GB WD HDD
Now, I want to spend no more than $300.00 USD on a watercooling set up, and I'm afraid I'm some-what new to it all. I want to OC my CPU and most likely my GFX card, so does anybody have any suggestions as to what I should get for watercooling, and what good websites to use to build a cooling system?
Also, I was looking at these:
http://www.koolance.com/shop/product_info.php?cPath=28_41&products_id=190
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233021 (little too expensive though)
Any ideas, or suggestions would help.
Any Triple Radiator - 50$
Swiftech radbox - 20$ (for hanging the rad outside the case. Omit this if you're up for some cutting ;) )
Dtek Fuzion CPU block - 50$
MCW60 GPU block with ramsinks - 60$
MCP655 pump -70$
Yate Loon fans and Masterkleer tubing - 10$
A Tline and some worm clamps, 5-10$ as required.
You can get it all from jab-tech.com
i like the d5 pump and i like my thermochill pa-120.2 its beefy compared to bip 120.2's almost twice as thick...
i like d-tek and swifteck cpu block and i like ek gpu blocks
yate loons are nice
http://www.petrastechshop.com/
http://www.performance-pcs.com/
once you do the cpu your going to want to do the gpu and some point, maybe after your next gpu card, but anyway get a good rad and a good pump so you you can have room for upgrades
The WC advice is all good.
I just do my CPU and NB.
I have a Nautilus 500,Swiftech Apogee GTX and an EK NB cooler.
You might want to reconsider the MB choice. I have the ASUS P5N32-SLI board and we have a real love hate relationship.
The board is pretty solid, but doesnt OC as well as the EVGA 680i A1 revision. Give that board a read-up and make sure of the decision before you buy the P5, there are times I wish I'd have waited and bought one of the EVGAs.
Now, my set-up runs rock solid and I have enjoyed building it, but I've been at it for almost a year to get where I'm at.
