I'm planning on changing my WHS MB and CPU, and while I'm at it the system HD.
I currently have a 160GB IDE system drive and two 1TB data drives at 44% full each. I want to get a new SATA system drive since the 160GB drive is old, as is the system board. I want a system that's 64-bit capable for the upcoming WHS Vail.
I've seen some pieces of info on how to do it, so based on that this is my plan:
1. Back up the file D:\folders\{00008086-058D-4C89-AB57-A7F909A47AB4} on an external drive.
2. Replace the hardware and reinstall WHS on the new system drive using "server reinstallation".
3. Reinstall service packs and add-ins.
Doing this the WHS will find the data drives and add them and their data into the pool, right?
Also, has anyone had a problem using a SATA drive as the system drive? I had to use the IDE drive because on the current system couldn't find the SATA drive I tried using initially. I don't know if it's because the VIA chipset driver didn't work for WHS, or the WHS just can't find SATA drives easily.
