need help turning off raid in bios
hclarkjr
i just had a samsung 970 evo plus installed and used their image software to to move windows 10 to it from my old drive. all went well except i can not get the magician software to see it and the samsung NVME driver says there is no samsung drive in system. i have found out that my alienware bios is set to raid for some dumb reason and dell will not tell me why saying they can not support me since i put new drive in computer.
how do i turn off the raid? i tried turning it off in bios but windows would not load. i have googled it and have not seen an easy solution for this. i hope you can help!! other than this the drive functions fine but i would like to be able to use the samsung software with my drive.
What was the original configuration, including the number and type of drive(s)?
If you shut it off, are the drives recognized in the BIOS even though they won't boot? If so, you could simply perform a fresh OS install.
