Need help troubleshooting
Keep The Volume Up
I have a problem with my motherboard. I have a Gigabyte DS3R rev. 1.0 and after I installed a Thermalright HR-05 SLI/IFX cooler on my NB, my video card port seems to have gone bad. I get no display on my monitor. I tried the video card (8800GTS 320) on another system and it works. The only way I can use my system now is to use an old PCI video card, and have nothing in the PCI-E x16 port. I am thinking the motherboard needs to be RMA'd. I am in the process of getting an RMA # from Gigabyte. I just need to find an anti-static bag for the motherboard, since I cannot locate the original.
I havn't been able to use my 8800GTS for over a month now.
I just don't seem to understand how my one video card port goes bad after a NB cooler installation.
My first option would be to try to start the system with the mobo taken out from the case. If that doesn't work, please recheck if the NB cooler's mounting mechanism doesn't touch anything else that shouldn't on the mobo, maybe you can try to put back your old NB heatsink and see what happens.
I removed everything from the case, and booted the system. Turns out, one of the rubber washers on the screws for the Thermalright HR-05 SLI/IFX was missing. The screw was right up against the motherboard.
I am frustrated with the mounting mechanism for the HR-05, so I put the stock Gigabyte NB cooler back on.
Now the fun part: Spending 3 hours putting everything back in the case with zip-ties for the extensive cable management.
I'm happy to see that it's working again !
Nice cable management have you there, think I saw it somewhere else too... :cool:
