Setup:
EVGA 680i
E6600
EVGA 8800GTX
Corsair Dominator 2GB 4-4-4-12
Antec Truepower 2.0
Problem:
Computer boots with a single beep, then hangs on 75, which is "Detect IDE; Detect IDE Device"
I'm running 2 SATA hds; only IDE present is with the cd-rom. After pulling the IDE cable, it still hangs on the same code.
I'm not getting any video; monitor light stays on standby.
Not a problem with my 8800GTX because I've been using it in my last build. (or my monitor)
24-pin power connector connected. I don't have an 8-pin supplementary, so, as the manual says, I have the 4-pin connectd to the 8-pin.
I also have a molex connected to the auxilary power for graphics.
Both 6-pin PCI-E cables are connected to 8800GTX.
Help!
EVGA 680i
E6600
EVGA 8800GTX
Antec Truepower 2.0
Problem:
Help!
