peppergomez
- Sep 15, 2011
Had this Samsung Syncmaster 305T for more than 3 years now, and I think it might have died.
The screen is flickering this sickly green/blueish color, and the icons look a bit blurry, like they are 16bit color. I made sure everything was plugged in properly, and removed and reseated my graphics card. Also turned off amd overdrive. None of this resulted in any improvement.
I took a screenshot of desktop when it artifacts and emailed them to myself, then viewed them on another computer. They look fine.
Tried on another computer and with a different cable. Same problem although the distortion is in a different pattern (thinner and only in center of screen) than on my home computer.
When I unplug the DVI cable from the monitor and the monitor cycles through the red, blue, green, white, grey and black test screens, there is no distortion.
Anyone got any ideas? Because it's a nice monitor, I'm hoping that it is fixable, like maybe there's a loose connection instead of the screen being shot.
Thanks.
Thanks.
