need help trouble shooting USB issue
darw_n
would there be a hardware mobo issue that would cause all USB ports to fail, with no ill effects on the rest of the system harware wise? USB devices (USB1 and USB2) is often registering as "unrecognized device" in winXPsp2, or sometimes a voltage error reported within winXPsp2.
in the BIOS, all voltages seem normal, and nothing is reprting with win error log, but I can not get any USB device to work.
Sometimes it creates a hard lock up if I plug my camera in, and my Ipod always comes back as unrecognized device
sorry if this question seems n00b-sh, its been over a year or so since I tried any trouble shooting.
basically, I am not looking for a straight answer from you guys, just some suggestions as to what i should be looking at, especially since the PC is not showing any other signs of issue.
thanks
Did you plug the devices in and then let Windows find/install a driver or did you install the drivers from an install program on a disk?
If you plug it in and Windows installs what it thinks is the driver, it may miss some of the components. Windows installs the minimum of what it thinks is required - usually just what is needed for communication and not for full functionality. You should install the drivers from the disk that came with the device (or download the latest drivers from the manufacturer's web site).
