Need help. Trim questions intel g2 SSD
oilfieldtrash
Okay. I installed windows 7 on a new motherboard I put in my computer. I forgot to set it to ahci before installing windows. So now my OS is installed and it's in IDE mode. I've read about the reg hack to install ahci drivers but then I was told if you don't install windows 7 with it set to ahci to begin with it won't support trim regardless if I change it back to ahci. Any help is appreciated.
It should support TRIM as long as you are using the Microsoft driver. Intel SSDs really benefit from using AHCI; if you make the change it should be good to go.
Thanks. I reinstalled the OS afterall. Only because I got a 5850 and the leftover nvidia drivers were interfering with my 5850.
