Well, I got to Quakecon 2 weeks ago, fired up my comp, and told the people around me that my system was acting weird (instability in a system that was generally rock-solid, just all around not of the norm). Instead of doing what I should of done, opening up the system and checking it out, I kept playing for the rest of the day.
Day 2
I come down and my computer is shut off. I figure someones just being a jackass, and I fire it up. It boots up and says that my ATI drivers aren't corrrectly installed. I reinstall them and it asks me to reboot. It comes back up and says that my power plug on my 9800 pro isn't plugged in. I *sigh*, pop the top and get a whiff of smoke. Apparently in the couple hour drive to Quakecon, my external power came a bit loose on my card and over the course of a day, cooked a pin on it.
It still boots up to that same error message now. I believe it's getting that error because it's not making good contact due to the scoring on the pin. Has anyone had a similar issue? Is there any way to salvage the card?
Here's some more pics:
Card Top
Pin Shot 1
Pin Shot 2
Thanks
Day 2
Card Top
Pin Shot 1
Pin Shot 2
Thanks
