Need Help to recover HD data file
BioSs
Get a 160g Maxtor 5400rpm fill with data files. Now, i can't open up the HD anymore.. Whenever i click on the HD, it show this disk in not format. I have like 130g data file in there and i really want to recover it. Who can tell me the best program to recover it? I have test couple recover program from downloads.com, but all i see it empty folder.
I've tried GetDataBack from the www.runtime.org with a some successes. You can try it out for a couple of files before buying it. They have a version for NTFS and FAT32.
Good luck!
for recovery FileScavenger
for repair DiskPatch
and for permissions (which may be your problem?)
disable simple file sharing and take ownership of files and folders
