Need help syncing
icamp31
Here is my situation, I have a program which is based on MS Access and it is no longer supported and the problem is to print from it I have to have a certain access file stored in the default directoy, if not it wont print. I want to use this across multiple PC's in multiple locations, so for instance it's installed on my home computer and my laptop and also my mother's pc as she does work for me.
1. How do I sync this? I just need it to sync a single file called crimconn.mdb across all three computers
2. I would prefer to keep that file in the cloud or online somewhere, but keep in mind the software has to think that the file is in it's default location called C:\prec
3. I tried MS Sync toy syncing to my dropbox folder, and it's not keeping it in proper sync, i.e. I'm losing data that was entered.
4. It would be great if dropbox allowed you to change it's default directory
5. I also tried GBridge but it is not allowing 2 way syncing
thanks in advance, I've been working on this for days!
