Need help setting up WC gear
aggpirate
WelL I have all my WC gear and all. I just need to know how to set it up. I can set it up outside the case and have, so thats not my problem. Were should i put the 3x120mm rad. I also have a enhiem 1250 pump. If it matters I have a li lian v1000b
Thanks!
why dont you put it on top like so many do or will it run longer than the length of the case? like externally, on top. like koolance does in their modded case.
Yea, you could just mount it and drill 2 holes for the tubes and put some C-strip or something around them to make sure it doesnt cut the tubing.
Just went and got the drill bit and i noticed that i got the wrong fucking block so i need a new one. 8 ( well my new vide card is not here so i can wait.\
Should i go
Res----> Pump-------> Rad---------> Waterblock---------> Res?
Should i go
Go like this : Res ---> Pump ---> Whichever order makes the smallest length of tubing
The only thing you need to consider is putting the pump after the res.
