Need Help Setting Up ATI Card
Spunkyasp
Hello,
I have a Radeon HD 6950 graphics card along with three ASUS ML248H monitors. I need some help in terms of what to plug in. I heard that you need an active display port adapter, so please send me a link to a decent one if you have the time. Also, right now I'm using a HDMI to DVI cable to connect to my graphics card, so I need to know if it's OK to plug the DVI to HDMI cable into the active display port to DVI adapter or if I should should purchase an active display port to HDMI and buy an HDMI cable. Also if I should purchase display port to DVI it has to be DVI-D (dual link). Let me know if I need to purchase anything else to get my build to work.
Thank you for your time.
The ML248H doesn't need DVI-D, so you can get by with the cheaper single link active adapters. HDMI and DVI are the same video signal, so it doesn't matter which you use.
Sorry, but I don't know what adapters are good - I don't need them.
