need help setting up a wireless printer
klumb
hello, im not sure that this is the correct forum for this so if it's not please move it for me.
anyway, my question is, i have one laptop and a netgear 54g wireless router, i'd like to have add a wireless printer.
but i have no idea what i need or how to hook it up.
here is what i found on the 1st few links from google:
http://www.superwarehouse.com/Linksys_Wireless_Printer_Server/WPS11/p/58795
and these below are really interesting but i don't have blue tooth on this laptop, and will this mess with the wireless link to the router?
http://www.amazon.com/gp/product/B0000DBJDO/102-5535327-2160119?v=glance&n=172282
any info will be appreciated
thanks
klumb
ok. the first one lets you do USB over wireless, basically, it's just an air-cable, if that makes sense. It won't cause problems with bluetooth or the wireless network, but it doesn't ~operate~ on the network either.
The second is a print server. Hook your printer into that, and it'll connect to the network, just like a computer would. Then you set the printer up as a network printer and go from there.
