Hi everybody! I currently have a netgear WNR2000 and just bought a selectable dual-band Dir-628. I've been trying to make the Dir-628 a wired bridge using the Wnr2000 as the main router so I can use the 628 for 5Ghz only and the netgear for 2.4Ghz. I changed the 628's IP to 192.168.1.2 but am not sure what to do beyond that. I can't access the router whenever I'm connected to the WNR2000 (the 628 is connected to a lan port on the netgear which goes into the wan port on the dlink). The WNR2000's web GUI is @ 192.168.1.1. I've set up wired bridges before in DDWRT (the 628 doesn't support DDWRT) but not sure what to do this time. Any help would be greatly appreciated. Thanks!
